NOTICE Notice: This is an old thread. The last post was 1427 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Ingraham Banjo clock "Nyanza"
    Can anyone tell me when these clocks were first manufactured? I seem to remember something about the early 1900's- Maybe 1917 or somewhere along that time. Were they made much earlier say in 1880's.
    Thanks for any help
    Jay
    Default Re: Ingraham Banjo clock "Nyanza" (By: Jay)
    A Google search reveals more about the Ingraham Nyanza clock. I don't know why the Message Board search doesn't come up with the same result.
    Take a look http://mb.nawcc.org/showthread.php?1...ay-Banjo-Clock
    H.J. (Les) Lesovsky, Alhambra California
    Default Re: Ingraham Banjo clock "Nyanza" (By: eskmill)
    Tran's Ingraham book shows the Nyanza from the 1915 catalogue, which may be the year they were introduced. The date on the movement may be of no consequence in this regard. But, 1880's, no.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Default Re: Ingraham Banjo clock "Nyanza" (By: Steven Thornberry)
    Thanks to both of you learned gentlemen.regards,Jay
  1. Small E. Ingraham Banjo Clock question
    By plove53 in forum Clocks General.
    Last Post: 12-18-2010, 09:14 AM
  2. Ingraham Banjo Clock
    By patpending in forum Clock Case Restoration and Repair.
    Last Post: 04-13-2009, 02:56 PM
  3. Bezel for Ingraham Banjo clock
    By Kevin W. in forum Clock Repair
    Last Post: 01-22-2008, 08:42 PM
  4. Ingraham Banjo Clock
    By Pete Riegel in forum Clocks General.
    Last Post: 01-26-2003, 07:24 PM
