Goal: $300, Received: $80.00 (27%) Contribute Now
Page 33 of 33 FirstFirst ... 232930313233
Results 481 to 486 of 486
  1. #481
    Registered User new2clocks's Avatar
    Apr 2005
    Pennsylvania
    608
    Default Re: Post your Lenzkirch clocks here.
    V_t,
    The clock is known as a free swinger, also known as a wag on wall. I guestimate its date of manufacture from 1895 to 1915.
    It does appear to be German, but to confirm that it is a Lenzkirch, a look at the movement will be necessary.
    Regards.
  2. #482
    Default Re: Post your Lenzkirch clocks here. (By: new2clocks)
    I'm thinking that it is a Kienzle. The case is not Lenzkirch or the pendulum. Of course, someone could have put a Lenzkirch movement in the case.
    Steve
  3. #483
    Default Re: Post your Lenzkirch clocks here. (By: LenzkirchFan)
    I hope I'm doing this right. Had no idea about these clocks until I found one today. I can see possibly the glass dome cover is missing. It's hand scribed a number on the backside and also someone's name. It may be "Manner". The number begins with a cursive "H" and it appears to be up to a 100,000 number but not sure. Missing a knob on the backside and the key. It is working and ticking just fine. Thanks in advance. - Jasmine
ID:	344159   Click image for larger version.
ID:	344160   Click image for larger version.
ID:	344161   Click image for larger version.
  4. #484
    Default Re: Post your Lenzkirch clocks here. (By: Starjasper)
    Update: serial number was inside.
  5. #485
    Registered User macaw's Avatar
    Jul 2014
    Minnesota
    559
    I just got this small wall clock at an estate sale, and I was probably the only one to leave a bid. From what I can find, it's 1877/78. Was this this a common case for Lenzkirch? Any info is appreciated.
ID:	347352   Click image for larger version.
ID:	347357   Click image for larger version.
ID:	347356   Click image for larger version.
ID:	347355   Click image for larger version.
  6. #486
    Default Re: Post your Lenzkirch clocks here. (By: macaw)
    Hello Macaw, You have a nice Lenzkirch model 536 spring regular. This was a popular design. I think that I have two in my collection. Enjoy!
    Steve
  1. Post Your Farcot Clocks Here
    By Charlie in forum Clocks General.
    Last Post: 02-22-2017, 07:45 PM
  2. Post your Gilbert clocks here
    By RJSoftware in forum Clocks General.
    Last Post: 11-02-2016, 08:30 PM
  3. Post Your Waterbury Clocks Here!
    By Sooth in forum Clocks General.
    Last Post: 11-17-2015, 08:35 PM
  4. Post your Jerome clocks here!
    By haneyk in forum Clocks General.
    Last Post: 12-01-2008, 07:29 PM
  5. Is there a 'Post your Cuckoo Clock here' thread?
    By Mike306p/Ansoniaman in forum Clocks General.
    Last Post: 01-20-2008, 11:42 AM
