Goal: $300, Received: $135.00 (45%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1433 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Default Trying to find info on a Seth Thomas clock I found in a thrift shop
    I'm a newbie who has recently become interested in older clocks and watches. I picked up a Seth Thomas clock for a buck in a thrift store, because it didn't work. After fiddling with it for a while it works and seems to keep good time, but strikes wrong on the half hour. I've heard 2- 8 strikes on the half hour in the first 48 hours. The hourly strike is usually accurate. So I'm trying to find out more about it, maybe it's not meant to strike just once on the half hour? Label on bottom says: Seth Thomas Clocks Thomaston, Conn., USA A division of General Time Corp Tradition-3W E961-000 German move Stamped on movement: A206-002 6413 2 Jewel Made in Germany for Seth Thomas Clocks The back legs and the the spires are missing, and from what I've been able to search, the movement is common to many of the later clocks, and it's not valuable. But i have not been able to find a match based on other pictures. I'd like to find out more about it, it would make a good starter clock to tinker with. Thanks
    Nov 2002
    39,379
    Default Re: Trying to find info on a Seth Thomas clock I found in a thrift shop (By: techgrh)
    Hi, Tech, welcome to the message board. Your clock was made in 1964. It has a Hermle movement (not a bad quality movement at this time). Your problem relates to how high the strike lever is being raised on the half-hour. Yes, it should only strike once on the half. It's a relatively easy repair for a clock repairman.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Default Re: Trying to find info on a Seth Thomas clock I found in a thrift shop (By: harold bain)
    Thanks so much for that information. I never would have guessed. Can that be controlled by bending the hammer or linkage?
    Quote Originally Posted by harold bain View Post
    Nov 2002
    39,379
    No. You will have to study the strike train to understand how it works. Note the lever that rides on the cam on the center arbor. Watch what it does on the half hour, and you should see the problem. You need to have a basic knowledge of how your clock works to fix it.
    Thanks again, I'm a novice and I have a lot to learn. To date, I have only made a few easy repairs that haven't required taking a clock movement apart. Will try and find a book about this movement.
  1. Trying to find info on movement identification
    By Earl Stedman in forum Clocks General.
    Last Post: 02-21-2012, 09:11 AM
  2. Trying to find info on this clock
    By rbaconii in forum Clocks General.
    Last Post: 07-04-2011, 01:01 AM
  3. Trying to find info and value on Varix Watch
    By SteveT in forum Wrist Watches
    Last Post: 07-07-2010, 02:18 PM
  4. Replies: 14
    Last Post: 07-24-2005, 12:21 AM
  5. Trying to find info on the EN Welch Garcia Kitchen Clock
    By john brendel in forum Clocks General.
    Last Post: 01-02-2003, 10:57 PM
