NOTICE Notice: This is an old thread. The last post was 1470 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 14 of 14
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    Default E. Lauffer Grandfather Clock
    "I just purchased a very old Lauffer grandfather clock. It runs beautifully - my question is, the chime block has 2 sets of chimes - one on either side, plus the chime hammers. I can only see how one set can work - the other side does nothing. Is the clock supposed to use both sets? Do you know where I can find a picture of how the Lauffer movement is supposed to look. this is only for 2 weights - no westminster chimes.
    Thank you
    Nancy
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    Default E. Lauffer Grandfather Clock (By: beststevens)
    well - since I didn't get any responses from my previous post, I'll try rewording this one and maybe someone will understand what my question is. I just bought an old E. Lauffer grandfather clock. It has 2 weights so means it only strikes half hr and on the hour. Usually these have on one set of chime rods - this clock has 2 sets and 2 sets of chime hammers. I cannot see what the second attaches to. Anyone know anything about these clocks that can help me. Thanks
    Nancy
    Registered User Burkhard Rasch's Avatar
    Jun 2007
    Twistringen
    3,953
    Default Re: E. Lauffer Grandfather Clock (By: beststevens)
    Iīm sure Youīd get more resonses if You posted some pics.
    To solve Your problem:take the mvmt. out of the case,try to build a kind of test-stand that enables You to run the clock in open daylight and see what happens.Pics please!!
    Burkhard
    Gigni de nihilo nihil,et nihil in nihilum posse reverti
    (Persius)
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    Default Re: E. Lauffer Grandfather Clock (By: Burkhard Rasch)
    thank you for the suggestions - I'll post some pictures.
    Registered user. jmclaugh's Avatar
    Jun 2006
    Devon
    3,531
    We really do need some pics. Clocks were made that strike and chime using only a single train for both functions. As it has two sets of hammers and only one is working it suggests there is a problem with the movement. I'm not familar with E. Lauffer as a maker so when you say two sets of chimes, do you mean gongs or rods.
    Jonathan.
  6. #6
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    as promised - pictures - it would also be nice to know about how old this clock is if you can tell. But I'm manly interested in the double chime.
ID:	181373Click image for larger version.
ID:	181374Click image for larger version.
ID:	181375Click image for larger version.
ID:	181376Click image for larger version.
ID:	181377Click image for larger version.
ID:	181378Click image for larger version.
    thank you!
    Nancy
ID:	181372   Click image for larger version.
  7. #7
    Greetings Nancy!
    Factory Ernst Lauffer GmbH. was in Schwenningen, the "The largest city in the world of clock-factories" as the citizen of Schwenningen called their city in the 1920ies.
    Ernst Lauffer GmbH. was founded in 1919 and was in business until WW2. Your clock was made I think about 1925. The movement is not a Westminster, but a Bim-Bam-Strike. I think the strike mechanism has a little proplem, but it is not out of order. Probably only the hammers must be set correctly.
    Here an ad of Ernst Lauffer GmbH. in 1925.
Name:	Lauffer, E. um 1925.jpg
    The left clock is very similar with yours, the prize was in 1925 about 60-70 Reichsmark.
    Enjoy your clock! If the strike mechanism is in order it will have a great sound!
    albra
  8. #8
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    Default Re: E. Lauffer Grandfather Clock (By: Albra)
    thank you very much - any ideas on how to fix the strike on the one side?
  9. #9
    Quote Originally Posted by beststevens View Post
    Nancy, I am not familiar with the correct terms, but other members of this board like Harold Bain will help you.
    albra
  10. #10
    Nov 2002
    39,628
    Nancy, I would need to see what's behind the dial to tell how the second set of hammers is tripped. If you take the hands off, you will find the dial is held on with 4 pins through the 4 dial posts. It should have a really nice sound with a pair of 4 note chords on the hour.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  11. #11
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    Default Re: E. Lauffer Grandfather Clock (By: harold bain)
    Thank you Harold - I'll get those pictures to you right away. Really appreciate your help with this.
    Nancy
  12. #12
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    Hi Harold - here you go. Hope these are good enough.
    Thanks again
    Nancy
ID:	181388Click image for larger version.
ID:	181389Click image for larger version.
ID:	181390Click image for larger version.
ID:	181391Click image for larger version.
ID:	181392Click image for larger version.
  13. #13
    Nov 2002
    39,628
    Nancy, your first two pictures shows an upside down v shaped toggle piece on the backplate that should activate the hammers on the left side from the front. The other end of the toggle will be impulsed by the strike wheel. You will have to manually activate the strike while you have the movement out to see if you can see where it might be failing. It will likely just be a simple adjustment to fix this, but I can't see well enough to tell you exactly what is wrong with it.
  14. #14
    Registered user.
    Sep 2011
    Florida
    164
    Blog Entries
    thank you - I thought that v shaped piece had something to do with it. I'll let you know how I do.
  1. Previous Info on Grandfather Clock ID Request.
    By Paul Lopez in forum Clocks General.
    Last Post: 09-19-2006, 02:11 AM
  2. Grandfather clock stopping
    By Steve G in forum Clock Repair
    Last Post: 01-17-2006, 01:36 PM
  3. Colonial Zeeland grandfather clock Chimes
    By Scottie-TX in forum Clock Repair
    Last Post: 11-13-2005, 07:01 PM
  4. Identification of Grandfather Clock
    By mfolinger in forum Clocks General.
    Last Post: 02-12-2005, 01:20 PM
  5. Grandfather Clock
    By apjarvis in forum Clock Repair
    Last Post: 11-21-2004, 06:12 AM
