NOTICE Notice: This is an old thread. The last post was 1326 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Default Pocket Watch Hand Falling Off
    Hi Everyone,can Anyone Help,Please.Minute Hand on Pocket Watch keeps Falling Off.The Hole in the Hand is Square,as is the part it fits on to.Can anything be done
    Kind Regards Phil
    Registered user.
    Mar 2008
    Gothenburg
    2,711
    Default Re: Pocket Watch Hand Falling Off (RE: phildee)
    If thee hole is to large it can be narrowed by simply giving it a tap with a flat staking punch!
    First check that the hand is properly seated. On some of these old watches the square is a bit larger towards the center and if the hand is not properly pressed down it may come loose quite easily!
    Default Re: Pocket Watch Hand Falling Off (RE: Skutt50)
    Hi Skutt,Thank You for Your Reply and Advice.
    I will Try both Methods
    Kind Regards Phil
    @Skutt, didn't some of the larger PWs with the square holed minute hands have a little tiny pin that held them on? I have probably 18s Seth Thomas clock that is basically a watch movt in a small case that has a tiny pin holding the minute hand on. Maybe the pin hole is plugged with dirt and not visible. Just a thought.
    Registered user.
    Mar 2008
    Gothenburg
    2,711
    Default Re: Pocket Watch Hand Falling Off (RE: samking73)
    samking73,
    Thanks for the suggestion.
    Personally I have not seen the pin solution but it sounds like a possible solution for a large pocket watch. I have of course seen it on clocks so why not on a large pocket watch........
  6. #6
    I have been collecting pocket watches for 58 years and have handled and worked on hundreds of Key wind watches. I have never seen a minute hand that was attached by a pin. All hands I have seen are friction fit.
    As was said above, make sure the hand is set down far enough on the cannon pinion. I use the proper diameter stake from my staking set to tap the hand into place.
    Tom
  1. Pocket Watch hands for a carriage clock
    By Hezekiah in forum Clock Repair
    Last Post: 02-14-2010, 03:05 PM
  2. Pocket watch Hands and fitting question
    By Jimbo76 in forum American Pocket Watches
    Last Post: 11-10-2009, 01:25 PM
  3. Marhha Pocket Watch Hands Needed
    By Boston in forum Watch Repair
    Last Post: 10-19-2009, 05:26 AM
  4. Minute hands falling off?
    By stewart in forum Clock Repair
    Last Post: 05-28-2006, 09:55 PM
  5. Pocket Watch Hands and Stems
    By mailman Sam in forum American Pocket Watches
    Last Post: 10-24-2002, 10:01 PM
