Goal: $300, Received: $115.00 (38%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1451 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    Registered user. brutusamiga's Avatar
    Sep 2011
    Cape Town, South Africa
    146
    Default cuckoo music box governor replacement
    Hello,
    I need to replace the music box governor for this cuckoo clock. I am however unsure of how to go about doing this and how to select the correct one. Timesavers has several available but the fans do not look like this one. Any information will be appreciated. The owner has a lot of sentimental value to the clock and I really want to help him.
    Thanks in advance.
    Bernard
    Attached Thumbnails Attached Thumbnails 20130601_220615.jpg   20130601_220725.jpg   20130601_220825.jpg   20130601_220842.jpg   20130601_221014.jpg
    Default Re: cuckoo music box governor replacement (By: brutusamiga)
    HI Bernard,
    You count the number of tines on the comb then choose the correct governor as I recall.
    Going back in time...Vernon
    Default Re: cuckoo music box governor replacement (By: Vernon)
    You need to know how many teeth on the pinion. Count them and let us know.
    Default Re: cuckoo music box governor replacement (By: shutterbug)
    Yes, the teeth on the driven pinion has to match. Usually it's 14, but this can not usually be varied.
    Further, you will probably not be able to find one that has the three arm lever mounting tab. You will probably have to mount the 3 arm lever on a new fabricated tab. This tab can be fastened under the comb screw. The newer ones are made this way and that is what you are buying. Actual replacements for the old part are long gone.
    Be sure to cover yourself on labor and parts cost.
    These things are really bad for your mental health.
    You can bend the tabs out on these and bush them. You have to be careful when bending them back though. Plus if the governor is bad the rest will probably need to be bushed also off the chime drum. After doing a few of these, you'll get better at it. When you can't find parts ya gotta do what ya gotta do.
    H/C
    R&A Sometimes we are retarded and sometimes we are advanced.
  6. #6
    Sep 2011
    146
    Default Re: cuckoo music box governor replacement (By: R&A)
    If you are referring to the pinion marked in red on the attached picture, there are 11 teeth. This then means Timesavers does not stock the item. The closest I can find is a 12 leaf from Perrin:
    http://www.perrinwatchparts.com/product/2684.aspx
    Is there a huge difference between the two?
    The other possible option is to order a complete music box. There is one on ebay, but the seller does not offer international shipping.
    Bernard
  7. #7
    Some of these are not available.
    H/C
  8. #8
    That appears to be the major difference in the governors. Perhaps you could order the one for the 12 tooth and just switch them out if your wheel is still in good condition. They're never "plug 'n play" and need slight modifications.
  9. #9
    Sep 2011
    146
    Good idea, shutterbug. That wheel is still in excellent condition. I will place the order. Thanks!
  1. Cuckoo Music Box Governors
    By Cuckoo348 in forum Clock Repair
    Last Post: 02-23-2014, 11:04 PM
  2. cuckoo music box
    By Cactus50 in forum Clock Repair
    Last Post: 06-15-2007, 02:28 PM
  3. Repair/parts for cuckoo music box?
    By Jonas Clark-Elliott in forum Clocks General.
    Last Post: 06-14-2006, 09:27 PM
  4. Sticking cuckoo music box
    By Chris in forum Clock Repair
    Last Post: 07-06-2005, 04:45 AM
  5. Cuckoo music box squeaks.
    By Michael Vala in forum Clock Repair
    Last Post: 05-02-2005, 03:48 AM
