NOTICE Notice: This is an old thread. The last post was 833 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Registered user.
    May 2013
    Liverpool England
    7
    Default Haller A.G. Wall clock
    Hello all,
    Just been given an old wall clock, face has Haller A.G. and Made in .... on it. The movement has been 'attacked' and parts left in a plastic bag. I guess it is beyond repair! On the movement are the letters T K and I guess the serial number 114,28. Also, 34 cm.
    I wondered if anyone on here could tell me anything about it, and also if replacement movements are available.
    Ray
    Registered User wow's Avatar
    Jun 2008
    Pineville, La. (central La.)
    1,808
    Default Re: Haller A.G. Wall clock (RE: Raymman)
    Ray, Welcome.
    If you can post photos of the movement and parts, perhaps we can tell you if anything is missing and help you get it back together.
    Will
    Will Walker (WOW)
    Registered user.
    May 2013
    Liverpool England
    7
    Default Re: Haller A.G. Wall clock (RE: wow)
    Quote Originally Posted by wow View Post
    Ray, Welcome.
    Will
    Thanks Will, I will try to get some photos up in the next few days.
    Registered User binman's Avatar
    Nov 2011
    Chatham England
    792
    Blog Entries
    Hi Raymman, Ebay best place for movements there is a couple of Hallers on at the moment, Just enter Antique Clock Movements.
    There is always tomorrow but i would like my clock fixed today
    Registered user.
    May 2013
    Liverpool England
    7
    Default Re: Haller A.G. Wall clock (RE: binman)
    Hi binman, thanks for the tip, I had a look on Ebay and only saw 2 movements and they were for Haller mantle clocks. I will keep looking.
  6. #6
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    Ray, welcome to the Message Board.
    When you're looking for the same movement, refer to the numbers you've listed above.
    114/28 is beats per minute and tooth count of the escape wheel. 34 cm is pendulum length.
    If those numbers don't correspond, the movement will not run properly in your clock case.
    Jurgen "tempus nostrum"
  7. #7
    Registered user.
    May 2013
    Liverpool England
    7
    As promised, here are the pictures of the face and movement. As I said before, I think it is past repair, so I will probably look for a replacement movement.
    Sorry for the obvious questions, but as a newcomer to clock 'maintainence', will other movements fit, and what is meant by 34cm? Is it the size of the movement or the length of the pendulum.
    Thanks for you help.
    Ray
    RayClick image for larger version.
ID:	178507Click image for larger version.
ID:	178508Click image for larger version.
ID:	178509Click image for larger version.
ID:	178510Click image for larger version.
ID:	178511Click image for larger version.
ID:	178512Click image for larger version.
ID:	178513Click image for larger version.
ID:	178514Click image for larger version.
  8. #8
    Feb 2009
    7,240
    I can't say now, if the movement is beyond repair; they are very rugged and can be
    repaired by a good clock repairer.
    The pic below shows you what is meant by pendulum length (in your case 34 centimeters).
    Producer of your clock was Thomas Ernst Haller AG., Schwenningen. They were taken over by
    Kienzle ca. 1930s.
    As a rule of thumb, consider that other movements will not fit.
  9. #9
    Jun 2008
    1,808
    Default Re: Haller A.G. Wall clock (RE: soaringjoy)
    Ray,
    You said the movement had been "attacked". I have seen many that are much worse. It can be restored to good running condition. I would try to keep everything original if possible. If you do not decide to tackle it yourself, search for a reputable repairer in your area and take it to them. Good luck.
    Will
    Will Walker (WOW)
  10. #10
    Registered user.
    May 2013
    Liverpool England
    7
    Thanks all for the comments. I would like to try to fix it myself, but know absolutely nothing about clock and watch repairs. Now give me a motorcycle engine!!
    If i were to look for a basic book, could anyone recommend such a book?
    Thanks again.
    Ray
  11. #11
    Nov 2002
    38,859
    This thread should give you a good idea of what most of us recommend for repair books:
    http://mb.nawcc.org/showthread.php?5...r-and-building
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  12. #12
    Registered user.
    May 2013
    Liverpool England
    7
    Default Re: Haller A.G. Wall clock (RE: harold bain)
    Well All, I have been looking for books, and parts for this clock and so far have had no luck on either. The lists suggested in post #11 are very expensive in UK, so it may well be that I will just look for another movement that will fit in the case.
  13. #13
    Hi,
    You have a very nice 1920's wall clock, which is well worth repairing. Haller is a very well known German maker.
    Regards.
  14. #14
    Registered user.
    May 2013
    Liverpool England
    7
    Default Re: Haller A.G. Wall clock (RE: Ticktocktime100)
    Hello again All,
    I decided to have a go at repairing this myself, and the first thing I came across was the cog feeding off the spring has a broken tooth. Are these available? I know the answer will be 'how long is a piece of string?' but if you could help me to identify it I would be most grateful. What information do you need to do this? is it the number of teeth on the shaft or the number on the cog?
    Once again, thanks for your help.
    Ray
  15. #15
    2 Raymman
    Hello! Do You identified Your clock now?
    I have exactly the same. And broken tooth...
  1. Antique German Haller/Dufa 1940's wall clock.
    By Ticktocktime100 in forum Clocks General.
    Last Post: 12-03-2012, 04:47 PM
  2. Help with Haller AG wall clock I.D. & Approx. Age
    By hdsoftail03 in forum Clocks General.
    Last Post: 09-07-2012, 08:29 AM
  3. Replies: 3
    Last Post: 02-14-2011, 02:21 PM
  4. Thomas Ernst Haller Wall Clock - What age ?
    By EliTom in forum Clocks General.
    Last Post: 02-27-2009, 04:38 PM
  5. Thomas Haller Torsion Wall Clock
    By jparker in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 03-07-2003, 02:07 AM
