Results 1 to 5 of 5
Thread: Elgin pocket watch problems
    Holt Guest
    Default Elgin pocket watch problems
    With just your description to go by, if I had the watch in my hands, the first thing I would check for, would be a loose "cannon pinion".
    The cannon pinion is like a clutch between the movement and the hour/minute hands, the "seconds" hand is "direct-drive".
    A loose cannon pinion is a very simple fix for a watch repairman. However this assumtion is based on a very vague description.
    Tommy
    NAWCC #156317
    If the balance swing looks decent and it runs the same on its back or on its face, it could just need to be cleaned.
    Watchmakers charge probably from $50-$75 for this.
    Good Luck!
    NAWCC# 156994
    Max Schaefer Guest
    What then would cause a watch to run too fast? I have an old Swiss watch of unknown make that happily ticks away but gains about an hour or so a day.
    Max
    Max:
    Your watch also could be in need of cleaning. Hairsprings will make a watch go faster if sticky from extra oil on them. To test for this, the balance unit, hairspring and all, is placed in hairspring cleaner, permitted to try and then tested in the watch. Another cause of running too fast is an extra coil being caught by the index. There are plenty of other problems which could be causing this, but the above are two of the most common.
    Max,
    If after you try Greg's sugestions, you still have the same problem, try demagnetizing the movement.
    Brian C.
    Brian C.
    Chapter 149 Member
  1. elgin 18S 11 Jewel Lever Set Pocket Watch Problem
    By finiteguy in forum Watch Repair
    Last Post: 08-08-2012, 06:59 PM
  2. Elgin pocket watch balance problem.
    By Jeff C in forum Watch Repair
    Last Post: 08-30-2007, 06:43 PM
  3. Pallet motion problem with Elgin pocket watch
    By Bill V in forum Watch Repair
    Last Post: 03-22-2007, 07:53 PM
  4. Elgin Pocket Watch Dials (Hair Line Cracks)
    By finiteguy in forum American Pocket Watches
    Last Post: 09-14-2004, 03:16 AM
  5. seeking San Diego area repair person (elgin pocket watch)
    By doug sinclair in forum Watch Repair
    Last Post: 11-28-2003, 02:36 AM
