Good Day........I've come across what I believe to be an 1821-1824 Teutonia Clock Manufactory Wall clock. I cannot locate any information on this item through the standard means of collector books etc. Does anyone have any sources of information pertaining to this clock. It is constructed of hardwood as the movement plates that have rolled brass tubes sized for bushings. It also contains a simple mechanical ratchet wheel and cam to operate the alarm bell that rests on top.........It looks as though this item might have been used in early day school houses mainly due to the volume of the steel bell when ringing. The alarm is activated by a 3rd hand on the arbor. Any help or info will be greatly appreciated.....Thanks
