NOTICE Notice: This is an old thread. The last post was 1397 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Hermle spring barrels
    Is there any way to tell which movements use no 20 or 21 barrels. I need two 20's which I understand is the same as no 21. Merritt's has repairman movements for $25, could be a cheap source of barrels and springs. Thanks for any help. Bob.
    Default Re: Hermle spring barrels (RE: Bob Fisher)
    Hello Bob, the 20 and 21 barrels are used in gthe 150 and 151 series of Hermle clocks. Why are you needing barrels ? they are not too tough to rebush. anyway I hope this helps.........tkd
    Default Re: Hermle spring barrels (RE: The Klock Dok)
    Thanks TheK,
    I was getting ready to dig into mount Hermle. The caps can be bought new, but the arbors will eat them up in a short while better to just replace the whole thing.
    Bob,
    Getting these return movements should be a good way to go, as long at the trouble they had was NOT with the barrel assembly. Tell them to check the barrels at the hook. If there has been a problem this hook ares will be pooched out.
    Default Re: Hermle spring barrels (RE: Willie X)
    Timesavers catalog has a chart for which barrels and which springs go with which Hermle movements.
  1. Hermle 1051-030A spring barrels
    By bangster in forum Clock Repair
    Last Post: 04-19-2011, 03:01 PM
  2. hermle spring barrel repair
    By dwlodyka in forum Clock Repair
    Last Post: 05-09-2010, 08:41 PM
  3. Hermle spring barrel cover removal.
    By FabRat28 in forum Clock Repair
    Last Post: 02-21-2007, 06:19 PM
  4. Hermle spring barrel lids
    By Jeff C in forum Clock Repair
    Last Post: 09-15-2005, 02:42 PM
  5. Hermle spring barrels
    By Chick Curry in forum Clock Repair
    Last Post: 08-08-2004, 10:39 PM
